Serpentine conversion, no problem :thumbup:
I would try to get a setup out of a donor 5.7L Camaro(Iroc) or Firebird (T/A -GTA) car from 88'-92'. These work real good and replacement parts such as PS pump, alt. and AC compressor (R4 style) are fairly inexpensive and readily available.
I just bought a new set for my 94' Suburban TPI conversion. Note - you can leave out the smog pump and route the belt to accomodate this. If you want to buy new brackets and pulleys, you can get them at
Street & Performance for $385 (click
here to view). You can see my bracket and pulley conversion
here.
But now that I think about it, you could also get the brackets and pulleys off a TBI model truck or Suburban, say 90'-95', since you are not concerned with the AC comp. & alt. spread required for the TPI throttle body. That would probably be your cheapest route considering that there are probably more Chevy and GMC trucks available to pull from.
Good luck, Ed
www.edgesz28.com
