1 - 6 of 6 Posts
I have no degree wheel and I need to set the timing on a 400 sm block Chevy motor with a .512 lift camshaft, can anyone tell me?
Timing?
Are you setting the ignition timing, or are you setting the cam timing (which is the only reason I can see for a degree wheel)?
There is no way to degree a cam without a degree wheel, unless you simply locate TDC on #1 and line up the dots.
1 - 6 of 6 Posts
