Yes I know most don't Hot Rod a 68 C10, some do though. And yes I know Hot Roding is all about swapping out Stock parts for better up-graded parts at times but here's my problem. I have a VERY MUCH STOCK 68 C10 that one or more of the prior owners has swapped out different years of parts I guess to keep it on the road. PROBLEM is what was swapped out wasn't right for the truck or the other parts being used with, meaning the Original Ball Joints (68 C10) were still in when the 92 front Disc Brake spindles were installed and here's where the Problem lies, a period correct (71-87 C10's) Center Link/Drag Link used for Disc Brakes was also installed. Now I know the 68 ball joint should have been changed to a 92 ball joints "but they wasn't". I didn't figure it all out untill I purchased the inner & outer tie rods, upper & lower ball joints, pitman arm and idler arm all were bought and saw they wouldn't fit on the 71-87 Center Link. Being I am restoring the truck to pretty much Stock Form (68 C10) I found the correct Brake system (drum brakes) and a 63-70 Center Link to be correct for the trucks year.
I know long winded,LOL. What I would like to get is the Measurements for the total lengths right and left sides when the inner & outer Tie rod and the adjustable sleeve is all put together and adjusted properly. What is on my truck now is wrong so I am Starting out from scratch. Anybody out there have a stock 68 C10 with stock suspension to get the measurements from?
I know it probably is a "needle in a haystack" question but I have Confidence in you guys or gals.
Thanks in advance for any info you could/can provide for me. Marvin aka mjgord51
