sheet metal work
The question about a sheet metal brake came up, so I put this together tonight. this piece is 18 gauge steel or .0478 or real close to 3/64 of an inch thick.
It took about an hour and a half including pictures to make this piece. This is stuff we can make at home, I have never worked in a sheet metal shop or ever used a sheet metal brake, so this is something us hobbist can do.
I used 1 1/4'' x 1 1/4'' angle iron, 1/4'' thick to do it. You could make stuff like this several feet long, I just did a hurry up on a short piece to demonstrate it.
Using angle iron clamped to a piece of sheet metal, put in a vice, you can bend it into curves a lot easier, so you can have 90% with a curve, theres a lot of ways to go on this.
I was going to make one more 90% bend, but it was getting late, and I don't have a problem with the neighbors, but hammering after eight at night, probably isn't a good thing.
I was in a hurry to do it, so the pictures aren't that good, but the piece you see, if you wanted to take a slapping spoon and a piece of angle iron, in your vice, you could make it perfect, but the pictures will show you the intent
http://www.2manitowoc.com/sheetmetal.html
Rob
Rob
