oil canning/sheetmetal buckle
I am welding on cab corners on a 71 k10. After butt welding it on, the rear flat area had a section where the pieces did not line up perfectly even, so like a dummy, instead of leaving it, I put some more weld there. After grinding down and hammering the weld, I have a buckle that pops in and out. I figured all the hammer doly work stretched the metal out so I did some shrinking work in the area, several times. The buckle is firmer and smaller but still there.
What can I do, short of some relief slits and rewelding again (more carefully) to fix this?
Prior to this problem my panel welding was good, darn it, I knew this was working to well to last!
thanks for any help!
