1 - 6 of 6 Posts
Just a quick question on adjustment screw for TH350
I was able to turn the screw a little and it moved the shift point in the right direction but I'd like to do a little more but I couldn't easily turn the screw and didn't want to strip the head
Is there a lock nut or something which you need to loosen before adjusting? If so, what and where?
What kind of head is screw? a flat or phillips?
Thanks!
Ed
Thanks!
Ed
flat type screw driver.
you can take a piece of wire like a coat hanger.......cut off a piece of wire, pound the wire end flat. FILE it into the shape of a screw driver and use that to adjust the screw inside the modulator nipple where the hose plugs onto.
:cool:
poncho62 said:
Which way do you turn the screw to up the shift point, Cros?
As you look at the nipple on the modulator , turn it clockwise.
this preloads the spring more.
I have turned the screw in so far that it unthreads. You can feel the screw skipping, then I backed it out 1 turn.
YMMV
1 - 6 of 6 Posts
