Thought I'd share.
New lift in rear of my '64 FJ40 & a swapped in powertrain altered the necessary length of the rear driveshaft. Thus, I needed to shorten the driveshaft 1/2". No concern, as this is a temp fix. When the rig layout is complete & I start the frame off build, I will have a custom shaft built for it. So, no fear, I jumped in.
Step 1 - Determined desired length by measuring flange-to-flange distance at full compression and full droop. Took my full compression distance and added 3/4" to allow for odd compression due to..ummm...jumping in reverse? Had enough stroke in this short shaft that I'd rather be safe than sorry. Thus, I am shortening it 1 and 1/4".
Step 2 - Cut a piece of 2 1/2" angle iron to the length of the tube portion I was going to cut (minus 1 1/4").
Step 3 - Ensured the angle clamped flush to the tube to assist in lining it back up. Used edge of angle to draw a line perpendicular to the cut for a reference point when reassembling the 2 halves, using a paint marker.
Step 4 - Mounted shaft in cold saw, being CERTAIN that it was going to cut at an exact 90-degree angle.
Step 5 - Cut out 1 1 1/8" piece. Width of blade makes this 1 1/4" total.
Step 6 - Chamfered outer edge of two cuts 45 degrees (about 3/32") and deburred insides. Took care not to shorten the pieces while chamfering.
Step 7 - Used angle iron and previous paint marker line to align two halves for reassembly. Clamped in place.
Step 8 - Tacked in 5 spots around shaft.
Step 9 - Used rough scotchbrite wheel on cordless drill to prep surface.
Step 10 - welded. Took some time and 'stitched' small lengths at a time to avoid warpage.
Step 11 - Used same wheel to scuff entire shaft & painted with hammerite.
Sorry, I didn't take pics of every stage...
