The 229 V6 has spun a bearing so the 305 must be put into service ASAP. The 305 is a 90 model year with a stock roller cam and dished pistons. I want to install a set of 906 vortecs milled .030 (62cc chambers after the mill). I think the 305 had 8.5:1 compression with 58cc heads stock, so if my vortecs are 62cc and I use a .015 shim gasket (Fel-pro FEL-1094 4.100 in bore, compressed thickness .015 in.) I should be back at 8.5:1 which is good for a daily driver. Anyways my question is do I need to use a gasket sealer of some sort during assembly? I searched this question and it seems that it was last discussed about 10 years ago so I just wanted to get some current knowledge on the subject. Thanks everyone for the help it is much appreciated as always.
Jay.
Jay.
