I bought a 78 truck that had a 350. i Was told it was all original. The former owner didn’t know Much about that. He really believed it had a 350. The a/c compressor and power and 2 power steering pumps with different brackets were in the bed of the truck.
‘’someone along the line had put an 85 305 in there. The harmonic balancer is wider and the timing mark at the 12 o clock position. I ran the numbers on the block. It’s 85 for sure. Passenger side dip stick.
I bought another 78 truck that was stock and had all the original parts. I now had a pretty good reference as to how it was supposed to come.
So ….…..one of the power steering pumps in the bed of the truck was 100% correct For 1978. All the correct brackets were there.
the correct a/c compressor and brackets for 1978 were also there.
the pulleys, alternator, water pump……I have No idea which engine they came from.
here is the problem.
when I bolt the power steering pump and a/c compressor. They do not line up With the 85 engine.
the a/c compressor falls short about 1/4”. since it’s mounted to the exhaust manifold bracket on the backside. There is no way to move it forward
the power steering pump also falls short about 1/4”
I was able to use washers to space it pretty close.
why are these not lining up?
is it because the harmonic balancer is thicker On the later 305 by 1/4 inch?
can I put an earlier, thinner harmonic balancer on there to make them line up with the ac bracket. As in put all 350 front end on there or will it mess with harmonics.
ive not dealt with later blocks. Just the 70s stuff.
