Guys,
I'm currently looking to get my 70 GTO A/C working. It has worked until a couple years ago when I pulled the motor to rebuild it. It was previously R12 and I am trying to decide on whether to go back to R12 or switch to R134a. I have some R12 I have purchased over the years so that's not an issue. I was prepared to switch to the R134a so I drained the R12 oil from the compressor and flushed it several times with R134a compatible ester oil. Now I'm having second thoughts about the switch to the R134a.
Here's my questions:
Can I use the Ester oil I flushed the compressor with if I stick with R12? If not what is the currently available R12 compatible oil.
I purchased a manifold gauge set online (waiting for it to be delivered). But I believe it is set up to work with R134a fittings. I know there are R12 to R134a fittings conversions, but are there also conversion kits to allow me to use these new gauges with R12 fittings? I realize I could use the R134a adapter fittings and just fill the A/C with R12 anyway, but I prefer not to convert the fittings if I'm still using the R12. thanks for your input.
Mike
Mike
