Living In The Past
Hi All,
I have a question regarding spark plug compatibility. I have recently got my 11:1 comp 355 sbc with 294S cam up and running using Autolite 23 plugs and all the other recommendations from F'Bird-88 (thankyou F'Bird-88 for all your online assistance - i did get the HEI dist) including locked out timing, transfer slot exposures etc and the thing runs great, idles CLEAN! And goes llike a rocket. However I have an issue with the long Autolite 23 plugs clearing the headers. One in particular #8 cyl is that tight that I have to pry the header pipe away from the head with I jimmy bar just to get the pug in!
And then when I fit the plug wire on, the boot touches the header pipe and shorts out - causing a miss under acceleration. I believe that the AR series autolite range are shorter and are considering running the AR23 plugs for more clearance, however when I check the comparability tab on the Summit catalog, it says that these are for V6 engines. I posed a question to Summit about this and they replied that the AR23 plug is NOT SUITABLE for sbc and that I must use the AR25? This plug is gonna be too hot for my application. My question is, is there any difference between the two plugs other than the heat range? Is the reach, thread size and wrench size still the same? Do Summit know what they are talking about? I'm confused! Are there two types of AR23's? Can any one clear this up for me please...
Duke
I never had any luck running autolites in a chevy, they usually do not have the proper resistance for the GM ignition system even running ignition boxes, and aftermarket components, I would suggest giving summit or jegs a call and get a set of the accel header plugs they are designed too solve the problems you are having oh and also get you a set of boot insulators to save you wires.
Living In The Past
Thanks 410, the insulation boots sound like a good idea, I'll get them
I ordered the AR23's and see how they measure up. Funny how you get different opinions?
I've heard nothing but bad wraps on accel stuff, I guess guys just use what works for them. The Autolite 23 has a .46" reach, I just hope that the AR23 has the same. Some sites quote the AR23 to have a .46" reach, but a cross reference site quotes them to have a .38" reach. Guess I'll just have to wait till they get here and work it out for myself.
Duke
Living In The Past
Thanks F'Bird-88, I knew you'd come through. The headers are a real PITA especially in my HK Monaro. You've been a great help.
Duke
