I am a little confused and hope you guys can give me some info. I installed some Autolite 3932 in my new 502 that is running AFR 305 heads. I used these plugs because that was what AFR recommended. I have 3 questions:
1. The plug I am running is a race plug with a very short tip which does not reach the center of the electrode. I checked the gap on the plugs out of the box and they are around 25,,,,very small gap. I attempted to change the gap but due to the very short tip and distance between the tip and electrode I was unable to find a tool to change the gap.
2. I am also running a MSD system and they recommend that the gap be around 50 for a starting point.
3. What is the effect on you motor if the gap is not correct and in my case not enough gap.
The car runs and starts fine but I am afraid I am missing out on either power or correct burn.
