1 - 20 of 24 Posts
Go ahead kid squeeze the wheez
I have a 383 stroker, 461x iron heads, mechanical dizzy, holly 3310 mechanical secondaries, light cam (13"hg at 750rpm idle) and I am running Autolite 85 plugs. I do a fair amount of driving on city srteets, not too much hot rodding and been thinking maybe I should go up in temp on the plugs. What do you think?
I use Autolite plugs exclusively with very good results.
You don’t have many choices with a resistor type power tip plugs like you
are running. The power tip plug wasn’t invented when those heads were
made. Autolite does make an 86, one number hotter. I don’t see a problem
running them when crusing around, the plugs don’t get very hot with light
throttle. If you do decide to run a few WOT blast, you could pop a set of
colder plugs in for safety.
Another thing you can try is to recurve the distributor adding a little more
initial and less centrifugal advance. That alone might clean up the plugs.
What type of ignition, are you getting a hot enough spark?
Discussion Starter · #11 ·
Present gap is .45 and I'm running a Mallory Unilite (with ballist resistor) with their Universal treet & Strip ignition coil.
Universal Street and Strip #29440
Primary Resistance 0.6 ohms
Secondary Resistance 12.3K ohms
Maximum Voltage 55,000 volts
Inductance 7.3 mH
Turns Ratio 105:1
Peak Current 100 mA
Spark Duration 500 uS
Does this help?
due to the resistor, you don't have enough volts to the coil for a good spark at .045 at idle...... you are at approx 9V at idle which would call for a approx max gap of .040
the coil can handle the .045+
try .042 as a compromise
a hotter plug at .045 will still be a weak yellow spark, due to the 9V
best(bang for the buck?) cure is put a HEI dist in it, 14V to the coil at idle with a .045 gap is roughly a 15-18,000V "blue" spark
work on getting the idle Hg higher, carbs want 15Hg to atomize the fuel, less than 14 is definitely in the "possible puddle" zone at idle
Hi jsdailey,
If you’re not running a capacitive discharge box like the
MSD 6AL, get one and your problems will likely go away.
pepi mentioned autolite AR25 plugs, they have a taper
seat, these won't work with the early iron heads.
Save a horse, Ride a Cowboy.
Besides being fouled wet, what is the color of the plug?
I'd probably try the hotter first.
Even at 9 volts 41,000 volts is more than enough to fire a spark plug at 4,000 volts. If you have a poor looking spark there is some other problem.
You could also try some spark plug tricks to make the spark sharper.
Like the grooved tip electrode, and filing the outside wire back to 1/2 the distance across the center electrode and then rounding the end. This ushrouds the gap and makes the fire sharper. A lot like splitfire type plugs.
Nothing will help as much as an MSD-6 multi-spark box. It will make life much nicer below 3000 rpm. :thumbup:
Discussion Starter · #16 ·
xntrik, dark and sooty, some moisture. Would I have to change my dizzy and coil to MSD and would this really be worth the price?
Some Punk Kid
You dont have to go all MSD to use a MSD box. MSD is just a favored company as they make quality products. Pertronix also makes multi-spark ignition boxes. Those are pretty much the only two brands I would trust.
jsdailey said:
...Would I have to change my dizzy and coil to MSD
MSD is worth every penny. No need to change the distributor and coil,
although the MAS distributor is much higher quality over the Mallory.
Sorry DeathRattle, I didn't see your post, it looks like we have the
same opinion on MSD.
jsdailey,
Going back to the plugs, I believe the autolite 85s are a hot heat range.
Discussion Starter · #19 ·
DeathRattle and automotive breath, thanks for the responces. Autolite makes an 86 which I thought I might try when the global warming (sorry, couldn't resist) ends. Will take a look at the MSD box also.
Some Punk Kid
No big deal. I have tried other companies and MSD is the only company that has earned my trust and that I will go back too. I am currently using a distributor from their value line StreetFire. Seems very good so far. It's probably better than most companies high end product.
1 - 20 of 24 Posts
