1 - 8 of 8 Posts
I just replaced a point type distributor into a 307 CI. which has 13mm plugs, what type, gap, and brand is everyone using. This is a stock 307 chevy with a 3 sp. in a 61 Bel-air
I ran AC R45TS plugs in my '72 307 motor. If your heads have tapered spark plug seats you can use the above plugs. I don't see a problem with running them with the HEI. Maybe the gap can be slightly larger w/ HEI.
10-4 on the 14 AWG from the distributor to the switched side of the fuse block
I will be off to Pimp Boys tomorrow to look for some AC R45TS or maybe some Dinso U-Grove or anything i can fine that is in the heat range of a R45.
By the way is a 43 hotter or colder plug?
Doc here, :pimp:
Don't forget to upgrade your Plug wires to an 8 or 8.5 Spiral core wires from the stock wires..or you'll have misfires, cross fires and RFI like a big Dawg..
Also assuming you removed the Ballast wire / Resistor from the circuit..else it will run like a muni bus if at all :rolleyes: :smash:
Doc :pimp:
Discussion Starter · #8 ·
Thanks all , yes I have rewired the HEI straight to the fuse box (Switched) and the wires were off of a running Camaro the same place I removed the distributor from.
1 - 8 of 8 Posts
