Since vortec heads are more efficient than the older designs, I need a timing base and curve for my engine, along with which vacuum advance to use.
My combo is a Vortec 350, standard bore, decked .010, Quench distance set at .043, KB 12cc D-cup pistons, reworked vortec heads, stock PM rods, Comp hydraulic roller cam, 206 duration @ .050 .500 lift, Performer vortec intake, SM Quadrajet, HEI, flame thrower coil and module, blue max spiral core plug wires, Hooker super comp headers coated by jet hot.
I haven`t ran it much since I`ve built it, I just need a ball park figure on the timing curve and I can take it from there, should the curve come in fast or slower? I set the base timing at 4 degrees BTDC, then connect the vac advance it goes to around 28 which seems to be too much, I was thinking on getting a adjustable unit. Any help is appreciated.
