I am going to spray a section with Evercoat Feather Fill. What is the minimum size gun tip that I can use for this product? How do I measure the size of a tip? I have venier calipers, so is that the correct way and where do I take measurements? Can I leave this stuff uncovered for a period of time, or will it absorb moiusture through to filler underneath?
Ron,
I have 4 HVLP gravity feed primer guns (Geo's)
1.5 that I use for 2K primers and 1.8, 2.2, 2.5.
For the FF/Slick-sand I like the 2.2 the best for a large area but the 1.8 works good for small areas like a side. I have used the 1.5 one time on a master cylinder and it just over atomized to much.
This is a porous primer and will suck moisture so should not be exposed outside.
All this is , is spray-able bodyfiller.
