I am useing a base gasket made by Holley. It's about 1/4" thick. It is the one that is open in the centre. The reason I ask is I am trying to get rid of an off idle stumble from a new Holley 670 Street Avenger. I've change cam/throttle postions, increased and decreased pump nozzle sizes, adjusted floats, check fuel pressure, Checked choke, checked vacuum advance and manifold vacuum, had 2 or 3 beer, set up fuel mixture, installed better air filter, played with timing, can't think of anything else right now but I still have a hesitation at any speed when stepping on the throttle even lightly. I had it also when taking off but managed to correct that part. It's on a 340 Dodge motor with about 15000 miles on it. Here's the other thing. The Edelbrock I took off had the same problems. I run electronic ignition, ballist resisitor and external coil. What else should I check?
