Ok well i finally finished building a 357 for my 81 Monte and im having a slight issue and im not sure what could be causing it. Ok ill try my best to explain, after the motor is warmed up you can give it all the gas you want and it will respond very nicely and it has no problems at all. the issue comes into play when the motor is under load. For example if i were to slap it into drive and try to take off quick the motor will start to sputter and stall. Jeeze i hope someone understands. Some times it will pop through the carb also but not often.
Its a 72 010 350 bored 40 over with a mild cam and 2.02 heads with 74-76 cc chambers. I thought it could be a fuel issue so i filled it up with a bunch of fresh gas and some fuel line antifreeze and got a new fuel filter. Also thought it was a timing issue but im pretty sure it isn't iv got it dead nuts were it needs to be. Also thought the distributer could be the problem so i had another one laying around that i slapped in and no luck. Only thing i haven't done yet is clean my carb which i will do tomorrow. If you need more info just ask. I am sure you will. Thanks in advance
