1 - 7 of 7 Posts
Hi Guys,
Can someone please tell me what the difference is between a spread bore and a square bore? I called summit about a manifold and they asked and I felt stupid not being able to answer the question.
Thank You
Jim
It'll go, or it'll blow...
Square bore- The 4 barrel carb's front and rear throttle plates are the same size.
Spread bore- The carb's rear throttle plates are larger diameter (like a GM Quadrajet or Chrysler Thermoquad)
http://teamrfc.gospelcom.net
spread bore
JimKramer said:
Hi Guys,
Thank You
Jim
when a rocket builder designed a cone for more thrust a speed shop engine builder got the idea to use the concept in a carburetor for better performance.
WFO
First- You dredged up a nearly 4-year-old thread and added NOTHING of substance to it.
Second- A rocket uses a NOZZLE for thrust- NOT a cone.
Third- WHAT?? :rolleyes:
305 Turbo-Fire 240hp
Thanks cobalt, Classic rookie mistake. He might unregister after that one. :cool:
1 - 7 of 7 Posts
