docvette said:
Doc here,
imp:
That plug sounds like it might be a Neutral safety switch / Back up lamps, coming from the rear and pan area..
I think the lockup solenoid would be a one or two wire plug at the bellhousing area (not sure, but I think that's where it will be) .
Doc
imp:
The plug is on the driver side above and behind the shift arm on the top of trans pan case, it is a four wire deal , but only two wires are used , the A & D terminals , the A is 12 volt + and the D goes to ported Lo Vacuum switch, whick would unlock the converter on WOT, I presume.
The wiring in the book shows + coming in on A and going through the T.C.C. solenoid ( torque converter solenoid) then it proceeds to a double wire connection on one terminal of N.O. Gov switch, then it proceeds to the D terminal.
I think the gov switch gives it a path to ground when it gets up to speed so it don't lockup at idle, also the ported lo vacuum swith is N.O. and it would also give it a path to ground (lockup) when the engine gets up to cruising vacuum. I think! Or a close facsimile thereof!
