I gave an interesting product a try a few days ago, "Squeegee prime" by Sherwin Williams. It's also available a NAPA stores under the Martin Senour label.
Well.....it isn't all it's cracked up to be, but it has promise. First off, to get this stuff to spread out will take some practice. It comes with a super nice fine edged soft squeegee, I need to try it on polyester putty but keep forgeting. The down side is the mixing tube needs to be replaced every time like a 2K adhesive or something like that. For the home hobbiest, that will be an added cost. But by the time I had spread it out three times on feathered out scratches on the car I was getting better at it. It is DEFINETLY not for big projects, but what the heck, maybe? It IS an iso free filling primer like a PPG NCP or the S-W which we spray every day at work and it does a great job. So you are applying a good primer even though it is pretty rough. but that should get better with practice.
It sanded out just as a sprayed primer would and it was paintable after sanding.
Is it going to replace spraying primer, not on your life in this version. But someday, it may, that is what big brother wants us to do in the industry.
Have any of you guys given this a try? I am sure other companies have something similar but S-W is the only one I have tried.
(click here) for gun
(click here) for primer
