SORRY I GOT A STARTER FROM AUTOZONE PART NUMBER 3510 WHEN I BOLT IT UP THE TEETH ON THE STARTER ARE ONLY GOING ABOUT 1/3 OF THE WAY INTO THE FLY WHEEL TEETH. THIS IS WITH THE PASSENGER SIDE OF THE STARTER SHIMMED WITH 3 FLAT WASHERS. THIS IS ALSO THE OFFSET BOLTS. I HAVE ALL THREE BOLT HOLES ON THE BLOCK. I HAVE TRIED THE STRAIGHT ACROSS STARTER BUT THE NOSE ON THE STARTER HITS THE FLY WHEEL BEFORE MY BOLT HOLES LINE UP.168 TOOTH FLY WHEEL
You should be using the staggered bolt pattern starter. Sounds like the ring isn't seated against the crank flange or the convertor is pulling the plate too much. What flexplate ans crank are you using. Internal or external balanced? We NEED info. A lot of it. Post anything you can think of.
I vote for the flexplate installed backwards....You wanna know why? I did it when I built my motor and installed my new 700r4 tranny. That really pissed me off to get everything hooked up, go to install the starter and oops, it doesnt line up. ain:
1 - 6 of 6 Posts
