My friend joined the army to be a mechanic and hasn't started his automatic el camino in 3 years. When he left it it ran and now he's back for a week and can't get it started. The engine is a 350 from a 82 chevy 1500. Just put a brand new edelbrock performer intake\edelbrock 750cfm carb\hei distrib. He's not gonna put a new cam in it until he's out of the army. We had a neighborhood guy who works on cars give us some ideas as to solve this put we\he can't figure it out.
So far we have:
Timed it to TDC
Replaced the oil and filter.
Squirt transmission fluid into the cylinders
New battery
New starter
New battery wires
New spark plugs (No plug wires yet because it isn't running)
We took the spark plugs out and let the engine turn over when we squirt transmission fluid in it. Then when we put them back in it only turns about an inch then stops. Turn the key again and it only moves an inch then stops. Hold the key down and it moves an inch and stops then 5seconds later it moves an inch and stops. So I took spark plugs 1-4 out and it started turning over and sounded like it wanted to start so I put the plugs back in and it moved about an inch and stopped. Nobody can figure it out they just keep saying the same thing check the wires check the starter check the battery. We moved the ground around and used a wire brush to clear the contact surface. We have done everything we can think of to just get the starter to turn the engine over while the spark plugs are in and it just wont. Any ideas?
edit: I forgot to mention it only has headers on it and there not on it all the way so there's nothing blocking the exhuast from coming out.
So far we have:
Timed it to TDC
New battery
New starter
New battery wires
