what would cause fuel to trickle out from below my boosters after a failed start. working with an electric fuel pump and duel double pumpers
ok thanx very much, after several attempts to start im pretty sure cylinders are full of 116 octane fuel. do u think i should address that or let it evaporate over night and try to start again?Float level or too much fuel pressure.
**** really...thanx i wouldnt have thought about the oil/filter change. just put almost 9q of royal purple in there too.Pull the plugs to drain and plan on an oil/filter change soon.
Hi, Thanx for the responce. This regulator is the non bypass type with no return line required. It's been working fine up until today. I was able reduce the pressure down to about 8psi thru my fuel pump. Havnt started it yet to see what the running pressure will be like. In the mean time I'll look 4 a part # on the regulator.Which part number Quick Fuel regulator....there are half a dozen.or more.
I'm wondering if you are trying to use a bypass style regulator(requires return line to tank) as a dead-head regulator(no return line).....the two types cannot be interchanged.
Or if it is meant for high pressure EFI....then you won't be able to adjust it low enough for a carb.
Open it up and check it out, there are only like 3 moving pieces inside the thing.....the diagfram, the spring, and the check ball or check piston. Dead simple, only slight spring pressure involved, fingers and thumb will hold it together.
hi ericnova72, sorry for the late responce. been remodleing my home getting it ready to put on the market and havnt had any time to work on my truck. didnt have any luck on a part number. fuel pressure is 8psi. i removed both carbs and removed the squirter assembly sprayed some carb cleaner in there also removed float assembly on the secondary's and cleaned them as well. when i turn the key on fuel is still flowing through the secondary squirters. fuel level looks correct thru the sight glass on th e float bowls.Hi, Thanx for the responce. This regulator is the non bypass type with no return line required. It's been working fine up until today. I was able reduce the pressure down to about 8psi thru my fuel pump. Havnt started it yet to see what the running pressure will be like. In the mean time I'll look 4 a part # on the regulator.
