if you sucked the tank dry, perhaps something got sucked into the primary pump in the tank?
P.S.
I'd sleep in it... lol :boxing:
P.S.
You have solved your problem,,..arch said:has oil pressure when its cranking... and the oil pressure saftey switch is for keeping the fuel pump circut open if the relay goes bad. But as far as I can tell, the relay is fine. Im thinking its more probable for something to have been sucked into the pump.... hopefully it'll unclog itself, enough for me to at least drive it home.
Although, I dont hear the pump sound when I turn the key... would something stuck in the pickup cause the pump to not make a sound?
