1 - 2 of 2 Posts
Hello, does anyone know were to get a rubber boot to go around steering column at the firewall my brother in-law goes to alot of shows and says he sees them on alot of cars they are square and have a taper to match angle of steering column I have 2inch s/c Thanks, Michael
If you can't find one, I've used the rubber seals from old pickups that had tanks behind the seat. They are also made to sit at an angle, and easily found at various truck suppliers. If they are slightly large they can be split at the bottom and a wedge cut out to make them smaller and easy to install without pulling the column.
$5 at Classic:
http://www.classicparts.com/1949-54-Gas-Tank-Filler-Neck-Grommet/productinfo/23-013/
1 - 2 of 2 Posts
