Here ya go.
One of the wires is the stop lamp switch --dunno color--position "P"
passenger stop lamp/signal----green---"N"
Driver stop lamp/signal----yellow---"M"
Turn signal feed from flasher----violet?---"L"-------(ignition buss)
Hazard feed----brown?---K-----(battery buss)
passenger front turn & dash indicator----DkBlue---"J"
driver front turn & dash indicator----LtBlue---"H"
Horn relay signal wire----black---"G"
the 3 pins on your harness that are not used may be for the "key in ignition" buzzer wired to your driver door-----my chevy has those same pins not used.
The "Neutral Safety Switch" is mechanically controlled by the shift lever position----should only start in N or P-------the steering wheels should only lock in P----key should only come out of the ignition lock in P
anyway---look at these pics-----wire colors may be different but the wire positions should be the same.
Yep---GM & Dodge used the same column, but dodge put the ignition switch on the side of the column vs on top of the column for GM
This really annoyed me when I put the tilt in my 82 Dodge-----the ignition switch interfered with the clutch operation (probably why tilt was only offered on AT Dodge trucks way back then). I had to modify my clutch pedal to go around the switch.
