need some help looking to convert my 69 bronco to tilt & put on a volo/sportline steering wheel. have a 79 ford van steering column with tilt. the wheel has six 5mm screws on a 70mm (2.75") diameter circle. what hub adapter would work for this application. thanks for your help :cool:
1950 Ford Custom
I think the wheel connection should be in the very center with a nut. Take that nut off and the wheel is locked on by a slight taper in the shaft. Use a gear puller to take it off (or a dead blow hammer watch your nose). Then measure the O.D. of spline and count the splines. You may have to change the hub in your wheel.
Can you post a picture of what you've got?
