I'm working on my interior in my '88 Mustang GT, and I have a couple of questions that I needed a little advice on. I'm replacing the dash because the old dash was cracked up.
1. I decided to pull the steering wheel out because I think that will make it much easier to get the dash back in place. I had no problem pulling the factory steering wheel off, but my question is since I had to use a puller to get the steering wheel off, how does it go back on? Also, the manual says you should'nt reuse the center bolt. Is that a must, can the bolt be reused. I was told by someone that the stock steering wheel could'nt be re-installed but I've never heard that before.
2. What's a good strong glue to use for cracked plastic interior pieces. I tried super glue, but it discolors the plastic,and I dont think gorilla holds that well. Any suggestions?
