My 1950 Chevy 3100 has a 1974 Firebird clip. The streering wheel won't return to center after a right or left turn. I have replaced all of the steering linkage, ball joints, and control arm bushings. The steering gear is the original from the Firebird. The pump is from a 1973 Chevy truck.
I have set the camber to neg 1/2 degree and the caster to positive 4 degrees. the toe in is 1/8 inch. The tires are P215/70R15 on 7 inch rims. I have tightened to steering gear until all of the steering play was gone and then backed it off 1/8 of a turn.
I read other posts saying that replacing the steering gear did not solve this problem for others. The steering wheel is centered and turns easily on turning pads or while driving.
I am at a loss about what to do next to make the steering wheel return to center after a turn
