I'm trying to come up with some plans for some storage cabinets for my garage. I'm leaning heavily towards using 16ga steel and forming sections to attach to the ceiling and back wall eliminating the need for the back wall and ceiling panels. I am going to make some with hinged doors (continuous piano hinge) but others I'l like to do with sliding doors due to space restrictions. The hinged doors will all be boxed or double flanged and flush fit with stops on at three sides. I may go with slam latches as well. Reasons I want to go with steel; #1. - Fireproof (I want as little combustables in my garage or have them well stored) #2. - I have full access to a metal fabrication shop and raw materials. #3 - I have minimum woodworking equipment and space
Dilemma: I would like to have the sliding doors look similar and function smoothly. Expensive hardware is out. of the question. If I use sheet metal for the doors I'd like them to be formed for rigidity as opposed to sheared blanks. I also plan on closing in the front of my work bench with a pair of sliders of the same construction.
Rollers / tracks are questionable due to the amount of abrasives and spatter that will be frequently present.
Any ideas on a simple cost effective approach? Any ideas would be appreciated... Thanks in advance
