I purchased a set of pre-bent brake lines but they were way off due to a disc conversion. As they are flared with fittings I’d like to use them if possible and I’ve rough shaped them to see if they might work - I now need to fit them to the car.
Best tools and method to straighten these brake lines?
The line is flared with a fitting so not sure if the multi rollers tool will work (due to the fitting and flare).
If I could lower the line for access, correct in shorter runs and not remove it from the car to straighten it that would be ideal.
