Let me start with a brief run run down on what is going on here.
I bought this truck, 1988 Chevy 2500 350 4x4 about 6 months ago. The truck was sitting for about a year before I bought it, and i was able to jump start the truck and drive away in it. After giving it a brief overlook, i replaced the battery, and drove it around town for a few weeks, putting 200 ish miles on it, without replacing anything but the battery. I moved about 160 miles away, and loaded up my truck and drove out of town. I made it to my new place just fine. I drove the truck for a few more weeks, with no issues. One day i went outside to start it up, and the truck would turn over, but would not maintain an idle, without me messing with the gas peddle, to massage the thing to stay running. If i gave it no gas, it would die, if i gave it a little gas, it would try to rev up, but still want to die. I was stuck in this loop of giving it a little gas, and letting back, then giving it gas, etc... The only way to keep the truck running.
From this i determined that I had a fuel distribution problem, so i started picking apart the fuel system. I started with a new inline fuel filter, when that didn't do it, i went ahead and gave it a standard tune up. New cap, rotor, plugs, plug wires, making sure i maintained the correct wire pattern.
Still had to do the same gas, no gas rhythm to keep it running...
I went ahead and replaced the TBI gasket, and that helped.. kinda... the gas, no gas rhythm was delayed out a little longer, by just a second or so more per gas, no gas rhythm cycle.
I dropped the gas tank and replaced the fuel pump, making sure i changed everything out correctly, etc. This solved the gas, no gas issue.
The truck now idles without any human intervention. After letting it run for 10 minutes, i noticed that the temp was around 220, so i turned off the truck.
I went ahead and replaced the water pump with a factory replacement (brand new one, NOT a referb) and replaced the bottom supply hose that goes from the bottom of the radiator, to the water pump. I also replaced the thermostat.
The truck still over heats. I can run the truck with the radiator cap off, and see the water moving, but it seems like the thermostat never opens (195 deg.)? I pulled the new thermostat out of the truck, and put it in a pan of boiling water with a thermometer, and it does open at around 195 deg, so that's not the issue. I also noticed that i correctly installed the thermostat with the spring part pointed into the engine. The cooling system has no leaks, that I am aware of, and have thoroughly checked out all the places where it could leak.
My question is:
What should I pick apart next? I did find a post in this forum about parking the truck at an incline, so that any air would make itself come towards the cap? I'm guessing i have an air bubble in the block, since i did replace the water pump, and the fluid level in the cooling system did drop considerably from that.
Also, The truck still inst running correctly. When i go to rev up the RPM's of the truck, it wants to stutter, almost stalling out, but doesn't die. I can back off the gas and the truck returns to an idle, and runs fine until it over heats.
I am wondering if these two issues could be related.
Another possibility is that there is a bad "mass air flow" sensor that could be creating an in correct fuel/air ratio, making the truck run really lean, therefor causing the over heating issue???
I'm stumped on this one guys. Any advice on what i should focus on next would be greatly appreciated!!
Thanks!
My question is:
Thanks!
