cutthroatkid said:
I went&looked @ the kits I yup you're right...but I allready gave it to my sisters husband so idk????he's been
[email protected] a custom bike shop forever&he runs drag bikes so I'm thinking he should be able to fix it,He did mention something about the plastic washers but said he would be able to come up with something,he's had a couple of novas too so idk???now I'm wishing that I would of got that kit first but I won't be able to get ahold of him before he gets to working on it.What if it leaks after he changes the bolt to a wider one?Then will it be too late to use. The kit?uhh this is expensive I put every dollar I have into this thing,once I paint it its gonna be killer!I just wanna go race this weekend&have a blast!
There are several possibilities.
One is that he'll use helicoils in the first place, after he sees what he's dealing with.
Another possibility is that the larger sized screw he uses will actually be the correct size for a helicoil insert. Or, the larger sized screw will still be smaller than the required threaded hole for a helicoil, so an insert can still be used.
Or, the repair he does works by using a larger screw, w/o drama.
Or, he totally trashes the carb body, leaving you carb-less until you find another used body or buy a new body.
You will know soon enough.
