pipe plug
Raidrbabe27 said:
I was changing timing belt on 93 ford probe and striped out the top hole that holds one of the pullies. Its alum and heli coil aint holdin. Wat do i do! 2.5l v6 ford probe 93. Need help
Drill and tap to a NPT size larger than the destroyed area. Screw in and Loctite a pipe plug. Use a steel plug with square extruded drive lug(solid plug) so you can cut it off even with the surface. Let the loctite cure over night, cut off the protruding plug, Drill and tap plug to the required size. You will have a steel insert in the aluminum that will never come out and never strip again.
Take care,Dave
