:thumbup: thanks double vision thays what i thought ,but i'd rather have someone elses input other than my own ,thanks again,i'm using 5.565 so i wont have to grind the bottom of the block where the rod bolts are near the oil rails ,i think the 5.7s will just hit there,and nova 406 i know what you are saying ,but the 350 with 400 crank will make a 377 also ,if you leave the block standard bore ,if you bore it .030 it will make a 383 ,thanks any wayi knew i could count on you guys on here ,later interceptor429:thumbup:
