I recently picked up a SB 360 for my 54' Plymouth project and had a few concerns arise about rebuilding the motor prior to dropping it in. This will be my first V8 build and I've looked into dropping in a MP 4" cast crank to add low end torque. The car/motor will be used for daily driving duties and I plan on running aluminum heads, dual plane intake and a 750cfm'ish 4bbl carb and mild cam for low and midrange power. So with the added stroke of the 4" crank, will the rings start to crap out prematurely and need replacing after a few thousand miles? I've read up as much information as I could on the 4" crank being used in SB applications but they all seem to be weekend only or track cars, nothing really daily driver oriented. Well any information would be appreciated. Thanks.
-Ian
-Ian
