400 ci bored 4.160
400 crank 2.100 stroked 2.00 upside for 327 5.7" rods
External Balance
Special older Weisco special order pistons for this application
Contact with roller cam on 4 rods.
I beam " Scat" rods
4 Rods require grind to clear cam.
Is there H beam 5.7 " rod that will solve my problem ?
I have noticed that some are recommented in Stroker applications.
Any Ideam
Thanks in advance for any ideas.
JTH
There is a small base circle cam that a lot of cam companies offer to solve this, but when you start stroking beyond the stock stroke and using beefier rod designs, many times you have to grind the clearance on several rods to make it all clear. So it isn't unusual for you to have this issue, just grind them enough to give .060 or so clearance and your done.
