a little more info would help like what kind of car, does the drum turn but you cant get it of or is it completely frozen. What have you tried so far.64Bird said:I've got a stuck driver's side rear brake drum. I've gotten after it with a small sledge. Don't know if I should heat it with a torch or not.
Any thoughts?
Even though the drum will turn, it is possible that the brake shoes are holding it. If the drums are old (and I assume so) it is possible that the shoes have worn a small ridge inside of the hub. I would back the adjusters off in addition to using a BFH and/or the screwdriver method. You can use the two screwdrivers on each side and see if the outer part of the drum will flex, that will give you a pretty good indication if the shoes are holding it too. If you can pull the outside of drum out with the screwdrivers, it is stuck on the hub. They are cast hubs and will crack or chip so be careful.64Bird said:Sorry, its a 64 Falcon with an Ford 8 inch rearend. The drum will turn so I'm assuming its stuck on the hub. I'll try more penetrant and a bigger BFH.
