I am having problems with oil blow by in my 350,that has approx. 30000 miles on it. It had sat for about 3 years. What can be done to loosen up the oil rings? Thanks Rich
Known traffic menace
There is some stuff out there called Sea Foam, You can get it at Advanced or Autozone I think, Might wanna give that a try. It supposed to work for stuck rings. Perry.
Doc here, :pimp:
Or you could pull the plugs and shoot a little ATF in there..rotate the engine (by hand) and repeat every day for a week or so..that might loosen them up without further wear.
Are you sure it's the rings? Could be dried and cracked Valve seals that are now dripping a little oil..you might want to check there..
BTW..when you re-fire it up don't be shocked ..It will smoke like crazy until the ATF burns off..
Doc :pimp:
Remove plugs: add good old Marvel Mystery oil and let sit over night and then turn your motor slowly. Repeat a couple of times and give it a try. But I suspect dried out valve seals as Doc sez.
Trees
