Hi all - im either going nuts here or i already am nuts. Just finished our 393 for the mustang - could NOT get it to run. comp test showed about 5 cylinders with ZERO compression..
Popped heads off - checked everything, deck perfect, heads brand new, reassembled. SAME!!! system is primed.. head botls were chased and I made sure they werent bottoming out (could run them right onto alu without the washer so def enough threads in the block).. Now when I run NO lash, cranking psi hits 180 in 3 rotations..
when I add just a touch on the lash, it drops to 130, at 1/2 turn (my usual on hydr lifters) NOTHING!! Then I tried a leak down test - 7% loss! zero leaks at valves, only some slight crank case loss - NORMAL!!
I thought yes - thats it! these must be solid rollers - jumped online and nope - Hydraulic lifters!!
Which is it? am i nuts or going nuts here.
Do I run zero lash and see how she runs? That does yield 180 cranking across the board pretty much.. or should I keep lashing till it just drops to 170, nudge back up to 180 and lock it there?
www.edelbrock.com
Hydraulic Roller Lifter Kit for Big-Block Ford.
Edelbrock part #97453 high performance hydraulic roller lifters for 1962-87 Small-Block Ford 289/302 & 1969-93 351W engines are the perfect match for street and high performance applications. Sold in complete sets of 16.
