lean said:i killed the motor in motor in my 91 caprice im considering buying a 1994 suburban 2 wheel drive it has a bad trans will my 1991 700r4 bolt and funcyion correctly thank you
lean said:so can i bolt it up will it shift by control of pressure or will it send codes that the trans is not plugged in and mess with everything
