1 - 9 of 9 Posts
Hello all,
The sound is not of my wallet emptying,, I have been reading dozens of post and no answers.
After Full throttle, to ~4500 rpm, when I let off the gas completely i get a sucking sound almost like a kid and a straw changing the pitch using their fingers to pinch it.
Both motors,, one AMC 360, one ford 400
over 11-1 compression,
mild cams [email protected] and 224 @ .050
aluminum heads and intakes.
Basic 3 inch air cleaners with breathers to the valve covers.
nothing crazy.
Does it with a old holley and a new QF 600 just the same. Motors run perfect now, over 15 inch vaccum, idle perfect, no leaks.
Any ideas??? I might try to film it and post.
Never had this on any other build over the years, does not do it on my SBC 406 with an AED
With or without an air cleaner mounted?
Either,,, I tried to film in the ford last night but it does not pick it up in the video.
I wonder if it is blow by pushing out somewhere? I do run 5/8 hose from the breathers to the underside of the air cleaner on both builds.
Race it, Don't rice it!
There isn't blow by on deceleration when the cylinder is 25+ lbs of vacuum.
Just an idea, perhaps the brake booster is venting excess.
Hates: Liver. Loves: Diesel
You probably have a vacuum leak under your dash. When you do a full throttle and then close the throttles at 4500 rpm, the manifold vacuum shoots sky high. Maximum suckage from the engine with a throttle plate blocking the flow. It's possible it was always there and you're just hearing it now because of a different air cleaner setup. My 96 Impala SS with a cold air intake made a HUGE sucking sound when you shut it off. The throttles were closed, and turning off the switch closes the IAC, so there was about a half-second sucking sound as the air rushed past the throttle to equalize the pressure.
1 - 9 of 9 Posts
