thanks. Yes i already have the 1102 on the shelf.Yes. One of my buddies is a 3rd generation automotive machinist. No idea how many Vortec heads he has seen. With all of the talk about valve lift limits on the factory Vortec, he maintains never having seen one of those heads in his shop unsafe for .450 valve lift. That covers the 1102 cam. The springs on the 906 heads will work great. Run it.
Do you already have the 1102 cam? If this engine isn't going above 3,500 RPM......the 1101 might be worth your consideration.
Not that it matters, but I think the 8 in your casting number is a 9 if you look a little closer. It is worth mentioning that the 906 heads will require a different intake manifold than the cracked heads would have used.
No reason to do that. Last thing you need is dual valve springs from eBay, assuming they would even fit! There are much better ways to go if you had a higher lift cam.ok. Another option then. I have a set of replacement (non vortec) springs SBC Stock Valve Spring Set Chevy 283, 327, 350, 383, 400, .450 Max Lift RV880X | eBay .450 Max Lift RV880X
Would those work on these stock 906 heads?
The retainers are different, and the new springs are double springs.
That's not what is considered a dual spring.....that is a single spring with a flat wound damper inside it.ok. Another option then. I have a set of replacement (non vortec) springs SBC Stock Valve Spring Set Chevy 283, 327, 350, 383, 400, .450 Max Lift RV880X | eBay .450 Max Lift RV880X
Good catch. I didn't even click on the link! No need to even evaluate them for use with his cam.That's not what is considered a dual spring.....that is a single spring with a flat wound damper inside it.
