Does anybody know the flow numbers and specs for the Summit Sportsman heads that they made in their shop about 8-9 years ago? I know they came with 69cc chambers, 2.05/1.6 valves, Crane 1.46 springs with 125lb/325lb specs and were drilled for the 400 steam holes. Found set that a friend had sitting on the shelf and only had one season on them. He switched to Brodix Track 1's and actually stayed the same in elasped time. The intake ports look like a 1205 intake and the the exhaust ports look bigger than a 1405. On the outside, they look like a stock head since the ends are not machined flat which is why I am very interested in them. Talked to Summit and they gave me the information above but that all they had. Wondering if any of you had info on these or your response if you ran these heads? Thanks
