I am confused, when I attempt to remove the rear main shaft assembly from the tranny case, it wont come out. The rear bearing retainer is loose and will only move 1/4 inch or so away from the tranny case.
I assume (no manual), that the proper sequence is to remove side cover, front bearing retainer, rear tailshaft housing, reverse shaft, rear bearing retainer with rear main shaft assembly. This is where the rub is. I cant get the forward part of second gear to clear the second gear on the cluster gear. In fact the rear mainshaft wont even pull out of the back of the front main shaft.
Anything I've pulled apart in the past would have just come apart at this point. I cant find a lock ring to take loose and just drop the interferring gear inside the case as I slide the rear shaft assembly out. Nor can I back the cluster pin out far enough to drop the front of the cluster gear out of the way.
What am I missing here????? Thanks for the space and...nice site
