1 - 6 of 6 Posts
^^^ Kind of hard to do five hole emulsion package with only 3 holes available?? ^^^
What emulsion package is in the rear metering block?? It is generally the same on both primary and secondary.
i agree, check close as many will be machined and threaded for a replaceable bleed but only drilled to a specific bleed size just below the threads and no replacement bleed is then installed.
To make it functional as a tunable set-up you may have to finish the drilling.
1 - 6 of 6 Posts
