Since I'm building with IFS and IRS I will use sway bars both front and rear. 7/8" or 1" diameter
A highboy style 34 Roadster with aluminium radiator and waterpump, headers, battery & gas tank in the trunk area will often end up with close to 50/50 weight ratio.
Sould I use same dimension on front and rear sway bars, or must the front sway bar be thicker than the rear one for some other reason?
Yes I know this is a very complicated question and there are lots of other factors here as well. Like the length of the bar, the length of the arms, the width of the suspension it is going to be mounted at etc. But I must start somewhere and then I would like to know if I should start with 7/8 rear and 1" front, or 1" both front and rear?.
