A mechanic just diagnosed the sway bar when replacing struts, and everything seems to be tight. Maybe you can help me here though and tell me if I'm correct - the sway bar actually runs along the width of the car, and then there are two bits on either end that connect from the bar to behind the wheels.
Should there be play in that part? There's gaps between the rubber and the metal and that seems wrong.
I did slide into a curb some years back, which I suppose could have bent the sway bar, it broke a tie rod and bent a control arm. No one mentioned or noticed anything with the sway bar. I'm just wondering if the garage was referring to just the linkage or the whole part - It seems weird that they would want to replace the bar, but not the linkage - wouldn't the linkage pretty much always go out first? There's no rust or corrosion at all - it's a 10 year old car, but most of its life was in Florida and up north it's been garage kept.
