I have a GM OEM serpentine system on my 454. The previous ownersaid the set-up was from a '84 dually. It has A/C, that is not hooked up nor will it ever be hooked up. I'm just using it as an idler pulley. I want to get rid of it but I can not find a OEM serpentine system without A/C, and I do not want to spend the money on a aftermarket set-up. So with all this being said....
I want to switch to a V belt set up. My question is will I be able to use my current water pump, alternator, and power steering pump if I do? Or will any of these things rotate in the wrong way with a V belt.
